Reverse command
RobB
Reverse command
Post by RobB » Fri Apr 08, 2022 2:10 pm
Wanting to swap the beginning and the end of a line, I found in the Modify menu the command 'Reverse' which works fine.
Its abbreviation is listed as 'RV'.
However, when typing 'RV' (or 'rv') at the command line, it tells me that it is an unknown command.
Rob
Linux Mint
Version:
3.27.1.0 (3.27.1)
Internet:
QCAD.org
Build Date:
Dec 13 2021
Revision:
2726424
Qt Version:
5.14.2
Architecture:
x86_64
Compiler:
gcc 5.4.0
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: Reverse command
Post by andrew » Fri Apr 08, 2022 2:15 pm
RV is the shortcut or keycode for this tool. You can simply select the entity, then hit the R key and then the V key.
The command for the command line would be "reverse".
See also:
https://qcad.org/doc/qcad/latest/refere ... oc/Reverse
petevick
Re: Reverse command
Post by petevick » Fri Apr 08, 2022 6:04 pm
That's because you don't type the shortcut in the command line, as Andrew says, select an entity the press R followed by V, do NOT type in the command line.
Pete Vickerstaff
Re: Reverse command
Post by CVH » Tue May 31, 2022 6:52 am
All,
On april 8 2022 Andrew added 'rv' as short command.
https://github.com/qcad/qcad/commit/243 ... aaa74c58fe
