I'm using this command:
/Applications/QCAD-Pro.app/Contents/Resources/dwgmapconvert -segment-length=0.5 -crs-in=EPSG:25831 -crs-out=EPSG:3857 -f -retain-texts -o file_epsg3857.dwg file_epsg25831.dwg
When comparing the file with the previous version without using "-retain-texts", I can see some texts are missing.
QCAD version 3.27.1
MacOS version 11.6.5
Any help appreciated,
Thanks!
[solved] When using dwgmapconvert with retain-texts some texts are missing
- qcad without -retain-texts.png (26.24 KiB) Viewed 2608 times
- qcad using -retain-texts.png (120.49 KiB) Viewed 2608 times
- qcad original file.png (77.28 KiB) Viewed 2608 times
Re: When using dwgmapconvert with retain-texts some texts are missing
Please attach or e-mail the file. Feel free to reduce it to the relevant parts.
Thanks.
I can confirm that text attributes are lost in conversion.
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2368
Bug report at:
QCAD 3.27.6 with a fix is now available.
Hi Andrew, works perfect now
Tested using the trial, just purchased the extended updates.
Thanks a lot!
Thanks a lot!
