After fresh installation on a Mac (not M1, but newest before that), the libraries for nesting command aren't found. Newest qcad version, macos 12.4
Fixed with copying the files from the plugins folder to /usr/local/lib/, but doesn't work out of the box. Just to mention: the filesystem is case sensitive.
Hardware info:
Modelnaam: MacBook Pro
Model-ID: MacBookPro16,1
Processornaam: 8-Core Intel Core i9
Processorsnelheid: 2,4 GHz
Aantal processors: 1
Totale aantal cores: 8
L2-cache (per core): 256 KB
L3-cache: 16 MB
Hyperthreading-technologie: Ingeschakeld
Geheugen: 32 GB
Versie systeemfirmware: 1731.120.10.0.0 (iBridge: 19.16.15071.0.0,0)
Versie OS-lader: 540.120.3~6
Serienummer (systeem): C02ZQ90XMD6R
Hardware-UUID: E3FAB1B5-84D5-5987-8D30-DE04E1732756
UDID voor provisionering: E3FAB1B5-84D5-5987-8D30-DE04E1732756
Status activeringsslot: Uitgeschakeld
Unable to find library's
- Schermafbeelding 2022-06-29 om 13.33.21.png (325.65 KiB) Viewed 2416 times
Re: Unable to find library's
Thanks. Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2376
