dwg2pdf cmd line tool unknown fonts missing
lloydzl
Post by lloydzl » Wed Jul 27, 2022 9:50 am
Version:3.27 professional, OS:Windows
I'm using dwg2pdf to convert formats, but most of the chinese charactors are missing, how can I batch replace all the unknown fonts with a specific font?
Most of the files have dozens of fonts, I can't replace them one by one on command line.
missingfonts1.dwg
(3.7 MiB) Downloaded 213 times
Re: dwg2pdf cmd line tool unknown fonts missing
Post by andrew » Wed Jul 27, 2022 9:57 am
You can specify multiple -font-substitution or -fs switches:
./dwg2pdf ... -fs SomeFont1 Arial -fs SomeFont2 Arial ...
lloydzl
Post by lloydzl » Wed Jul 27, 2022 10:10 am
Thanks,I know this way, but I don't know what fonts of the file the users upload, I have to extract all the fonts by command first(maybe 10~100 different unknown fonts), it has more trouble, can I simplely use wildcard(or other way if it has) to repalce all the fonts with one?
Post by CVH » Thu Jul 28, 2022 4:31 am
Remark that there is a polyline in your example file that isn't rendered correctly by QCAD.
Handle 0x2a316a
Two 180° degree arc segments, Global Width 28.901376, Global Z -7999.999
It is rendered as a solid filled circle with a diameter of about 1600 units (Drawing units = None).
This is a reported issue, flatten to 2D will correct this.
AutoSave or Save (-As) will report:
Exception occurred. Entity NOT saved: 2b924d
Exception occurred. Entity NOT saved: 2b9250
3D polyline with arc segments flattened to 2D.
The last two messages are not concerning the 0x2a316a entity what will remain as it is.
Post by CVH » Thu Jul 28, 2022 5:35 am
Similar topic, same author, marked as solved:
https://qcad.org/rsforum/viewtopic.php?t=8736
In this case there are 16 different fonts used.
I think that this is still possible within the 8191 character limitation.
Automated I would replace fonts one by one.
Post by andrew » Thu Jul 28, 2022 11:36 am
This is not currently possible.
Please note: We've sent you an e-mail and private forum message regarding your QCAD Professional license. Please reply to the e-mail or private message at your earliest convenience, thanks.
