Help with Trace Bitmap - New Feature
Posted: Fri Oct 07, 2022 1:31 am
Hi Andrew
QcadCAM Version: 3.27.8.0
Build Date: Oct 6 2022
Revision: dea3962
Qt Version: 5.14.2
Architecture: x86_64
Compiler: gcc 5.4.0
OS: Linux Mint 20.3 x86_64
And
OS: Windows 10 Pro 64bit
This is a well welcomed feature in Qcad but I seem to be having trouble with it..
I've looked at the Help file but I need some guidance on the actual settings for tracing.
Below is an example from Inkscape v1.1 Appimage "I have used this for years" the Trace Bitmap settings are default values.. I tied default values in Qcad but could not achieve the desired result, I also tried setting to monochrome and played around with the thresholds but it shows a black screen and on an odd occasion locks up...
Any help will be much appreciated and I'm very happy that this feature will now be a part of Qcad
Please see below sample screenshots, image file used "Face.png" and dxf output from Inkscape...
PS FYI I had the same issue with previous Qcad Build 3.27.7
Revision: dea3962
Qt Version: 5.14.2
Compiler: gcc 5.4.0
And
