Viewports in common Block
Post by CVH » Sat Oct 29, 2022 6:11 am
I discovered that one can add Viewports to common Blocks.
https://www.qcad.org/rsforum/viewtopic. ... 965#p38958
Normally Viewports are intended to be inserted in Layout Blocks.
One can not add a Viewport of a part of Model_Space to the Model_Space Block itself.
That will show no preview at all and on placement we get an exception warning.
'Cannot create viewport in model space.'
But one can add a Viewport to a common Block, it shows a preview and there is no exception on placement.
This is probably not 'intended behaviour'. :!:
If one inserts such a block in Model_Space then the Viewport area doesn't display the content.
Not in model view, nor on paper.
The Viewport contour is handled just the same as on a Layout.
Viewport-CommonBlock.dxf
Various comments included
(126.31 KiB) Downloaded 395 times
Tested/created with QCAD Pro 3.27.6.0 Win7 32bit msi installer.
PS: The behavior of the file is exactly the same under 3.27.8 :wink:
