QCAD Linux installer target directory
Post your question about installing or upgrading QCAD.
Post by andrew » Wed Jun 08, 2022 8:12 pm
From a QCAD user:
How do I set the target directory when installing QCAD under Linux?
Re: QCAD Linux installer target directory
Post by andrew » Wed Jun 08, 2022 8:14 pm
You can use the --target switch to specify the target directory. For example:
./qcad-3.27.6-pro-linux-x86_64.run --target /home/user/my/target/dir
Alternatively, you can extract the tar.gz anywhere on disk and start QCAD from that directory:
tar xfvz qcad-3.27.6-pro-linux-x86_64.tar.gz
cd qcad-3.27.6-pro-linux-x86_64
./qcad
michele85
Post by michele85 » Wed Aug 03, 2022 12:44 pm
Tried ./qcad-3.27.6-pro-linux-x86_64.run --target /home/user/my/target/dir, but it does not work. Qcad is always installed in the /home/opt directory.
What can I do? I'd like to install it in a hidden folder like /home/.opt.
My OS is Arch linux.
Post by andrew » Thu Aug 04, 2022 9:04 pm
I cannot reproduce the problem. You might want to install from tar.gz instead (simply extract and run from the directory that is created).
Return to “QCAD Installation and Upgrades”
