installation failed on Ubuntu 25.10
Post your question about installing or upgrading QCAD.
mahdi
Post by mahdi » Sat Oct 18, 2025 7:48 pm
HI, Trying to install QCAD on a new Ubuntu 25.10 machine gives me this error:
zarg@zarg-Dell-G15-5530:~/Scaricati$ ./qcad-3.32.4-pro-linux-qt5.14-x86_64.run
Verifying archive integrity...Error in MD5 checksums: fe5d865b0953e88fb5c02b67d3e76eab is different from ea27b64d4038b49c46d4fc0fa098bdfd
Does anyone know why? I tested it on other PCs with Ubuntu 25.04 installed, and this does not happen.
ciao
g
Re: installation failed on Ubuntu 25.10
Post by CVH » Sun Oct 19, 2025 2:39 am
If the checksum of the downloaded package fails ... Have you tried to re-download the package?
mahdi
Post by mahdi » Sun Oct 19, 2025 10:21 am
Yes, I did... many many times
ciao
g
Post by andrew » Sun Oct 19, 2025 10:41 am
Please check the MD5 checksum of the downloaded file:
$ md5sum qcad-3.32.4-pro-linux-qt5.14-x86_64.run
6f736d7a86c0c71ae03f133728670708 qcad-3.32.4-pro-linux-qt5.14-x86_64.run
If it doesn't match, your browser likely gives you the same cached file over and over again without redownloading. Clearing the browser cache should fix that.
mahdi
Post by mahdi » Sun Oct 19, 2025 12:48 pm
So I tried ...
change browser ... failed
clear browser cache ...- failed
download, installed on different pc just to test it out, saved on USB and copy on ubuntu 25.10 ... failed
ciao
g
Return to “QCAD Installation and Upgrades”
