[solved] Line Types Not Displaying Properly
Post your question about installing or upgrading QCAD.
chungrdmv
Post by chungrdmv » Tue Mar 18, 2014 1:46 pm
I just purchased version 3.4.6.0 (3.4.6) and noticed that not all line types are displaying correctly while I was editing a layer on a drawing.
The result of my "test" are as follows:
Continous - OK
Dot - Displays as continuous
Dot (Small) - Displays as continuous
Dot (Large) - OK
Dash - Displays as continuous
Dash (Small) - Displays as continuous
Dash (Large) - OK
Dash Dot - Displays as continuous
Dash Dot (Small) - Displays as continuous
Dash Dot (Large) - OK
Divide - Displays as continuous
Divide (Small) - Displays as continuous
Divide (Large) - OK
Center - Displays as continuous
Center (Small) - Displays as continuous
Center (Large) - OK
Border - Displays as continuous
Border (Small) - Displays as continuous
Border (Large) - OK
Is this "normal"? Am I missing some line type files?
I am running QCAD as a 32 bit application on a 64 bit Windows 7 machine.
Any help is greatly appreciated.
Thanks,
Randy Chung
Re: Line Types Not Displaying Properly
Post by andrew » Tue Mar 18, 2014 1:55 pm
The line type display depends on your drawing size (line patterns are defined with dashes in the range of about 2-12mm).
If a pattern would get very dense, QCAD shows a continuous line instead.
You can set up a global line type scale in the drawing preferences:
Edit > Drawing Preferences > General > Linetype
Screen Shot 2014-03-18 at 13.54.19.png (60.03 KiB) Viewed 9702 times
chungrdmv
Post by chungrdmv » Tue Mar 18, 2014 5:22 pm
Thanks for the information. Perhaps someone could add a note in the QCAD ebook in the layer introduction section indicating this.
Thanks again.
Randy
Return to “QCAD Installation and Upgrades”
