[solved] QCAD3.INI
Frank60
[solved] QCAD3.INI
Post by Frank60 » Mon May 12, 2014 4:09 pm
There's a new release 3.5.1: can I safely use the current 3.4.7 Qcad.ini file without having to generate a new ini file? (and manually make all personal settings to the ini file :( )
Thanks,
Frank
Re: QCAD3.INI
Post by andrew » Mon May 12, 2014 4:13 pm
Yes, the ini file should always be backwards compatible. Of course you should never have to move settings manually.
Frank60
Re: QCAD3.INI
Post by Frank60 » Wed May 14, 2014 6:00 am
Well. It didn't work going from 347 to 350. Not just rulers, but colors are different too.
viewtopic.php?f=33&t=2904
Frank
