How to run Qcad -3 in Ubuntu 14.04
vkadal
Post by vkadal » Fri May 16, 2014 2:00 pm
I recently upgraded Ubuntu to version 14.04. But I am unable to launch Qcad. But I was able to use it in earlier 12.04 version. Kindly advice me to resolve this issue
Moderator / Drawing Help
Re: How to run Qcad -3 in Ubuntu 14.04
Post by Clive » Fri May 16, 2014 3:25 pm
What QCAD version?
hungerburg
Post by hungerburg » Sat May 17, 2014 2:06 pm
Vkdal, here is how I do it: download tar.gz package, open a terminal window, then type (replace 3.5.1 with the version of your package)
cd /opt
sudo tar xvfz /path/to/qcad-3.5.1-pro-linux-x86_64.tar.gz
/opt/qcad-3.5.1-pro-linux-x86_64/qcad
Here on Ubuntu 14.04 it starts just fine. Maybe during the system upgrade you have lost a prerequisite? Use this line to learn what is missing:
LD_LIBRARY_PATH=/opt/qcad-3.5.1-pro-linux-x86_64 ldd /opt/qcad-3.5.1-pro-linux-x86_64/qcad-bin |grep found
Post by andrew » Mon May 19, 2014 11:40 am
I cannot reproduce this problem here on a fresh installation of Ubuntu 14.04.
vkadal: Please post your exact version of QCAD, thanks.
vkadal
Post by vkadal » Mon May 19, 2014 12:40 pm
The version is Qcad-3 purchased on 05 Sep 2010. I am unable to find out exact version. So I have given you the date of purchase. I could t is 3.0RC2. This number I could locate in the splashscreen.png file.
The command LD-LIBRARY..... is not working.
Kadal Amutham
Post by andrew » Mon May 19, 2014 1:02 pm
Kadal: You are using an old release candidate version of QCAD which will likely not work on newer operating systems anymore (except for Windows which usually provides good backwards compatibility).
I've mailed you some information about updates.
