[solved] Problem with installation on Kubuntu 14.04
rezotina
Post by rezotina » Sun Jan 11, 2015 3:44 pm
I am trying to install QCad from downloaded installation package. I tried it as a supervisor. I'm always writes that: File /home/ov/Downloads/qcad-3.7.5-linux-x86_64.run opened in UTF-8 contains invalid characters.
Can you help me te installation.
thank you OV
Re: Problem with installation on Kubuntu 14.04
Post by andrew » Mon Jan 12, 2015 10:24 am
It looks like you are opening the installer file inside a text editor instead of running it. Please execute (run) it instead as an application.
You can find detailed instructions for installation on Ubuntu based systems at:
http://www.qcad.org/en/component/conten ... ion-ubuntu
rezotina
Post by rezotina » Mon Jan 12, 2015 9:03 pm
Thank you,
The installation was successful. :wink:
