[solved] Installation of Qcad on Ubuntu 14.04lts
Posted: Mon Jan 19, 2015 7:51 am
I have used the following codes (Obtained from an existing topic in the forum) to install Qcad on my PC running Ubuntu 14.04lts and it works succssfully
cd /opt
sudo tar xvfz /path/to/qcad-3.5.1-pro-linux-x86_64.tar.gz
/opt/qcad-3.5.1-pro-linux-x86_64/qcad
1)The issue am having is that each time I have to use Qcad, I have to open the terminal and paste the following codes
cd /opt
2)Also all the dxf and dwg files format I have on my PC are not link directly to Qcad. I have to open Qcad using the method stated above and then using Qcad to open the files.
I would like to konw if its possible to create a executable icon to launch Qcad and also to open the dxf and dwg file format directly by double clicking on them.
Finally, am using a Qcad pro version 3.4.2 which is not the last upto date version available. Could this be causing the issue??
Neshen
cd /opt
cd /opt
Neshen
