installer of 3.12.5 not working
J-J
Moderator
Post by J-J » Tue Jan 12, 2016 9:45 am
Good morning,
I have a problem with the Windows 64 bit installer:
Before, the installer was offering a QCAD directory, not this time?
any idea...
JJ
Re: installer of 3.12.5 not working
Post by andrew » Tue Jan 12, 2016 9:58 am
Does it work if you add a directory to the path (i.e. "C:\Program Files\QCAD" or "C:\Program Files\QCAD 3.12.5")?
Moderator / Drawing Help
Post by Clive » Tue Jan 12, 2016 10:19 am
Hi Guys
Same problem for me, but "C:\Program Files\QCAD" works fine.
J-J
Moderator
Post by J-J » Tue Jan 12, 2016 10:32 am
Hello Andrew,
Yes, the installer will work when typing in a directory.
But I now have a problem to launch my default start-up drawing with the command:
"C:\Program Files\QCAD-3.12.5\qcad.exe" -exec .\template.js
The program will launch, but closes right away, it launches OK if the script is not invoked.
I normally have "template.js" and the file in the main directory where QCAD resides
"templates.js" is a small script you wrote for me some time ago.
JJ
Post by andrew » Tue Jan 12, 2016 10:40 am
OK, I've uploaded fixed installers.
I don't remember what template.js does.. Perhaps starting with -enable-script-debugger helps to figure out what is going on?
J-J
Moderator
Post by J-J » Tue Jan 12, 2016 12:30 pm
OK, but how can I invoke the debugger? :oops:
Here's the script:
var mainWindow = RMainWindowQt.getMainWindow();
var doc = mainWindow.getDocument();
var di = mainWindow.getDocumentInterface();
di.importFile("nouveau_dessin.dwg");
di.regenerateScenes();
di.autoZoom();
doc.setFileName("");
JJ
Post by andrew » Tue Jan 12, 2016 12:53 pm
OK, is there any reason why you cannot use File > New from Template.. to create a new drawing using an existing template document?
That would be through the -enable-script-debugger command line argument:
"C:\Program Files\QCAD-3.12.5\qcad.exe" -enable-script-debugger -exec .\template.js
J-J
Moderator
Post by J-J » Tue Jan 12, 2016 1:17 pm
It is just more convenient to have it by default when I launch QCAD
I'll try the command line
thanks
JJ
J-J
Moderator
Post by J-J » Tue Jan 12, 2016 2:54 pm
here's the debug window
QCAD closes on subsequent step
Sorry, no knowledge in scripting...
This script was still functioning with the previous release, (QCAD in X86 directory)
JJ
J-J
Moderator
Post by J-J » Tue Jan 12, 2016 11:05 pm
just some more info: at the first stop of the debugger, the file is indeed visible in QCAD. Something must be different in the following steps and generating a conflict. I reinstalled previous version, script OK. e_confused .
JJ
