Install older version
marieke
Post by marieke » Tue Feb 12, 2019 1:30 pm
I just installed the latest pro-version but it turns out that if I add the script 'MyTools' QCAD fails to launch. I really need this script, and in the older version of QCAD it worked fine.
Does someone know how to solve this problem? Or where can I find an older version to install? (I do need the professional version)
Re: Install older version
Post by Husky » Tue Feb 12, 2019 7:58 pm
Multiple post regarding the same issue will not speed up the process! smf already told you that he will try to fix the script for the next official QCAD release.
J-J
Moderator
Post by J-J » Tue Feb 12, 2019 8:09 pm
I have the latest QCAD release, the directory "my tools" works as usual (win7-64). I normally install in a directory where "my tools" resides before:
my tools.jpg (54.72 KiB) Viewed 3711 times
JJ Win7 pro-64
