[solved] QCAD window does not launch/open
bgaines
Post by bgaines » Sun May 05, 2019 4:45 am
I just purchased and downloaded QCAD Pro 3.22.0 win64, when I try to open the program no window opens, but I see the app open on my task bar. I have windows 10. Don't know where to go from here.
The same thing occurred when I tried to use the trial version, which I removed from my cpu prior to downloading the pro version.
Re: QCAD window does not launch/open
Post by Husky » Sun May 05, 2019 5:43 am
Hallo,
did you installed the msi or the zip archive?
bgaines
Post by bgaines » Sun May 05, 2019 6:11 am
I figured it out thanks.
