qcad not open menu's option File,edit ...
Posted: Fri Dec 20, 2019 8:04 pm
by lfrau
I install qcadcam-3.24.0-pro-win64-installer.msi and it's work well, after using with 2 monitors and close, now when I open de qcad, looks like it works, but the menus not open and is always in full window and options for minimize, maximize and close not appear.
i unistall, reboot and install again and do the same, don't work.
sorry for my English
Re: qcad not open menu's option File,edit ...
Posted: Fri Dec 20, 2019 8:58 pm
Please refer to this page to learn how to reset your QCAD configuration:
Posted: Fri Dec 20, 2019 9:04 pm
Thanks for your report!
I can reproduce the issue.
Please try to toggle the Full Screen mode with the key "F11". That should give you access to the menus. Keep us posted on that.
What is your operation system? Windows 10?
Posted: Fri Dec 20, 2019 9:09 pm
@Andrew
F11 will deactivate the Menu function in QCAD/CAM. QCAD/Pro works flawless in Full Screen mode.
Posted: Fri Dec 20, 2019 9:21 pm
OK. I cannot reproduce that here. The menu is just all the way at the top but seems to work fine (QCAD/CAM 3.24.0), also after restarting.
Posted: Fri Dec 20, 2019 9:33 pm
I tested the behavior on Win10/64 / same .ini
Looks like that is not only the last update. Version: 3.21.0.0 was still working but not the other ones between Version: 3.21.0 and 3.24.0
Posted: Sat Dec 21, 2019 12:39 am
by lfrau
thanks, F11 appears buttons min,max and close and menus works. if push F11 not.
:oops:
