I've just installed QCad Pro 3.25.2 on ubuntu 20.04 and the menus are not working, they did work correctly in the non pro version. I've installed QCad int the /opt directory using the --target option and belong to a group that can access it. every thing else seems to be working correctly.
I've read on the forum that depending on the flavour of ubuntu qt can misbehave and that changing the native option on the preference menu can solve the problem,but I can't access the preference menu (catch 22 ) is there a way to access it on the command line?
Philippe
QCad Pro (CLosed)
- Registered Member
QCad Pro (CLosed)
Re: QCad Pro
Yes, type 'preferences' in the command line or press Ctrl+,.
See also:
https://qcad.org/doc/qcad/latest/refere ... references
See also:
- Registered Member
Re: QCad Pro
Thank you for your answer, the problem was using QCad on a multi monitor systems on a secondary monitor, the menus don't like it but if I run QCad on the primary, it works. So for now I've change my primary monitor
Cheers,
Philippe
Cheers,
Philippe
