Open Source Nesting
Open Source Nesting
Post by Husky » Mon Aug 01, 2016 11:06 pm
Hi everybody,
if somebody is in need to use an Open Source Nesting Software try SVGnest. http://www.svgnest.com/
It works with svg files which easily can be exported/imported with QCAD Pro. Maybe a suitable solution for occasionally nesting needs.
Note: This tool isn't yet perfect but normally good enough for small cnc projects. Just test it - maybe it suits your needs.
Re: Open Source Nesting
Post by andrew » Tue Aug 02, 2016 2:11 pm
Thanks Husky, this looks great. I'm sure this will come in handy for CAM users.
Post by Clive » Wed Aug 03, 2016 11:53 am
Thanks Husky for highlighting this useful tool, it is much welcomed :D
Okay here's my test with this and a few important notes:
1. This is a drawing with 101 thumb tacks I wish to laser cut.
Thumb Tacks.dwg
(27.81 KiB) Downloaded 703 times
Thumb Tacs.jpg (78.47 KiB) Viewed 26348 times
2.After exporting the file to SVG in QCAD the first result is not good, as you can see 'SVG Nest' doesn't like Arcs or Splines :cry:
Arcs and Splines don't work.jpg (61.47 KiB) Viewed 26348 times
You can see that some of the thumb tacks have the 'domed' head inverted, these are the ones which are splines.
The domed heads which look good are arcs ... but you have to change the whole of the outline to a polyline in QCAD in order to get this result ... if you don't you will get the inverted result!
*Note - if you try to work with a spline and change this to a polyline it doesn't work either (not for me anyway).
3.So currently for the best results when using SVG Nest, use lines, arcs and change to a polyline .. or of course just use polylines in QCAD. The result worked for me.
Use Lines and Polylines only.jpg (65.75 KiB) Viewed 26348 times
4.Next, export to SVG in QCAD and upload this to the SVG Nest program. Follow the instructions (so simple) and change the configurations as required.
5.This is the result after 4 iterations. Not bad hey 8).
Nesting Complete.jpg (71.83 KiB) Viewed 26348 times
6. Then download your nested SVG file and open up in QCAD and job done :wink:
Once again a big thank you to Husky.
Nest Result.dwg
(54.66 KiB) Downloaded 660 times
Post by Husky » Thu Aug 04, 2016 5:53 am
Clive wrote:Once again a big thank you to Husky.
You are more than welcome! :wink:
kakaronaldo
Post by kakaronaldo » Thu Jan 05, 2017 7:48 am
this is nice...and i agree with the third comment...
http://www.soran.edu.iq
Post by Husky » Sat May 04, 2019 3:50 am
Another open source nesting software: Deepnest
In short: Offline software, available for Windows, Mac and Linux. It can read DXF, SVG and Corel CDR files and it can write DXF and SVG files.
I'm still testing it but till now ..... I like it! :wink:
Check it out by yourself:
https://deepnest.io/
nkp
Post by nkp » Sat Feb 29, 2020 9:34 pm
Hi!
I understand correctly?
1. it only works on 64 bit OS
2. The application requires an Internet connection
thanks
Post by Husky » Sat Feb 29, 2020 9:56 pm
depends on the used program ... :shock:
SVGnest is only online available what means it needs always an internet connection.
Deepnest can be installed on your computer and needs only for the download of the program an internet connection. After that it works without it.
32/64 bit? Probably doesn't matter ...
nkp
Post by nkp » Sat Feb 29, 2020 10:50 pm
for Linux is available for download file Deepnest-1.0.5-x86_64.AppImage
nkp
Post by nkp » Sun Mar 01, 2020 12:09 pm
I installed ubuntu 18.04 x64.
the application starts, but with a long delay (about 10 seconds)
How fast does it load for you?
PS
very good app.
Thanks to the author for the open source code !!
but (probably) this application is not very common,
there is no place to chat with users ((
Post by Husky » Sun Mar 01, 2020 6:25 pm
20 seconds on Win10/64 ... :(
Post by John Hyslop » Sat Mar 07, 2020 11:53 pm
Hi Husky
I tried Deepnest it's very good..I did download it and it runs offline but it doesn't read in the DXF files or nest? It must rely on a connection to work...unless they've changed the software recently..try it with no internet connection a see..
I get this error :-
" could not connect to conversion server"
Post by Husky » Sun Mar 08, 2020 12:46 am
I never tested that but you are right. After I cut my cable it wasn't working anymore. :( :( :(
But ...................... it looks like it needs only for a dxf the internet connection. The same drawing exported with QCAD to svg works without WIFI. 8)
Try it. :wink:
BTW: Do you have any idea how to repair a WIFI cable what is cut in half ... :oops:
Post by John Hyslop » Sun Mar 08, 2020 1:27 am
Haha... you're funny....so it opens SVG files.. cool I'll give it a go...
Post by John Hyslop » Sun Mar 08, 2020 1:39 am
Hi Husky
Yep you're right SVG no problems at all.. that's really good thanks for pointing that out,I was going to uninstall because things that rely on the internet can some day disappear and leave you with useless software...
It's definitely a keeper now...
Cheers...
