Open Source Nesting
Re: Open Source Nesting
Post by Husky » Sun Mar 08, 2020 6:54 am
John Hyslop wrote:
Sun Mar 08, 2020 2:33 am
... somehow it seems to of reversed some arcs? any idea what might be going on...
I'm sorry, I have no idea. :(
Post by CVH » Sun Mar 08, 2020 8:26 am
Pls, attach your files.
That would not be the first issue with SVG.
Post by John Hyslop » Sun Mar 08, 2020 9:40 am
Hi Husky
I did attach the svg file? did you want the dxf too?
See attached...
Shape-01 - Rev B.dxf
(374.58 KiB) Downloaded 304 times
Post by CVH » Sun Mar 08, 2020 5:16 pm
Rather all arcs look to be reversed in your screengrab.
The dxf and the re-imported svg consist both out of 53 non-reversed arcs.
Setting something else as 'White' and 'Default' for the lines:
Looks ok in a browser.
Opens ok in Inkscape.
So it is a Deepnest issue.
Did you try reversing the arcs, or conbined to a polyline?
Post by Husky » Mon Mar 09, 2020 7:16 am
Hi John,
Hi Husky
Nope - I haven't ask for the dxf :wink:
Post by John Hyslop » Mon Mar 09, 2020 10:34 am
Hi Both
I reckon it's the nesting program too..
I also opened up svg in inkscape but only displayed rectangle but AutoCAD opened the dxf with no problems..
CVH yes same issue with polylines...
Silly me rectangle was white on white saved from inkscape as DXF and all arcs are ok..👌
Post by John Hyslop » Mon Mar 09, 2020 11:51 am
Hi Husky
Deepnest cannot process SVG files correctly every one I've tried so far fails all arcs are reversed..the pc I'm using is offline..I bet it will work while online..pity it looked very promising..
Post by Husky » Tue Mar 10, 2020 5:59 pm
You lost! e_surprised Online / offline does not matter. SVG fails in both scenarios. Good to know ...
Post by John Hyslop » Wed Mar 11, 2020 12:44 am
Damn...there is always qcad/cam at a small investment 😁
Post by John Hyslop » Thu Mar 12, 2020 4:49 am
Hi Husky
I made this for you... it will save you a fortune on internet cables LOL
Works in Windows up to 10, not sure about Linux....
PS If you don't want it delete this post :-)
Net-On-Off.zip
(217.86 KiB) Downloaded 287 times
Network On & Off.jpg (7.18 KiB) Viewed 10701 times
Post by CVH » Thu Mar 12, 2020 12:35 pm
Deepnest is what they call 'abandonware'.
Jack Qiao (Jack000) never did surface again after 2018.
https://github.com/Jack000
http://jack.works/
There is a fork with later commits:
https://github.com/InfernoEmbedded/Deepnest
Deepnest is based on SVGnest from the same author.
Last commit there is from april 2019.
Deepnest and SVGnest topics are spread over many sites and pages.
I did came across some demands and commits about arcs but not as we are experiencing.
Found a mail address: jak000 at gmail.com
(had to chop that address or the msg failed as spam)
Many are trying to reach him.
Pitty, it looked promising.
Post by John Hyslop » Sat Mar 14, 2020 1:20 am
Hi CVH
Interesting.. thanks
