This forum is intended for the QCAD Professional Version.
In a recent Pro version (>=3.30.0) that would be by shortcuts (
Tutorial: 2.1 Keyboard Shortcuts).
In order of appearance:
,C |
,N |
,U |
,A |
,D
Besides that you can navigate in the Options Toolbar using TAB.
Typing in a value is send to the first input field.
From your screen capture this might be an older QCAD Pro version or it is taken from a CE version (Referring to other posts) .
The 'a' of attributes is underlined, Alt+a would toggle 'Use current layer and attributes'.
The former (<3.30.0) or the CE functionality was/is indeed incomplete.
You can not address 'Copy' with the Alt key for example and 'Angle by cursor' has nothing to underline because it is an action button.
The dialog presents more combinations with the Alt key.
QCAD is constantly enhanced and/or updated with new functionality.
Originally QCAD is/was geared to be a GUI (Graphical User Interface) where most things are addressed by the cursor.
The first question would already be:
Why typing in '
rotate' in the command line while the shortcut key sequence
RO starts the tool just the same?
Besides that the
RO action button is typically included under the Modify menu or on the Modify toolbar, CAD panel and matrix panel.
The next question is:
Why use the keyboard extensively to enter complex and fully written out textual commands?
Example:
rotate -copy:1 -current-layer-and-attributes:no -angle:cursor
In the time I release my pointing device and typed that I have:
Hit
R &
O, entered values in indicated fields and clicked on the required options buttons.
All without releasing the pointing device.
Things have evolved since the DOS era when everything was textual and only as green on black.
Since loading software was with 15 or more floppy's (AutoCad, Spice, ...).
I don't see you type in the command
Swipe left or
Swipe down on your (not so) Smart-Phone.
