Improving Performance
Locked
Post by andrew » Fri Feb 09, 2018 3:20 pm
When dealing with large or complex drawings which are slow to zoom in / out, you might want to adjust the following preferences:
Switching to Draft Mode
View > Draft Mode
Deactivate Highlighting of Entities under the Cursor
Sometimes it is not the display that is slow but finding and highlighting the entity closest to the mouse cursor. This is especially true for dense drawings with a lot of details. You can disable entity highlighting under:
Edit > Application Preferences > Graphics View > Behavior > Highlight entity within range (uncheck)
Reducing Arc Resolution
Edit > Application Preferences > Graphics View > Appearance > Minimum angle step for rendering arcs (degrees) (increase)
Hatches
Edit > Application Preferences > Graphics View > Appearance > Timeout for Hatch rendering (decrease)
Dashed Lines
Edit > Application Preferences > Graphics View > Appearance > Display entities with more than N dashes as continuous (decrease)
Locked
