Preferences greyed out on a Mac
Locked
Redisha
Post by Redisha » Tue Nov 03, 2009 5:45 pm
QCAD 2.2.2 Mac OS 10
I downloaded and installed the software and unfortunately it opened in Danish. However my preferences is gray'd out so I can't change it.
Any suggestions?
Adair
BrianH
Mac Snow Leopard Problem
Post by BrianH » Sat Feb 20, 2010 11:28 pm
Can anyone Help.
In middle of project changed Cross Hair size and was told to restart QCAD.
When this was done the User Language changed away from English. But now I cannot change Preferences back to English as the Preference Menu is Greyed out.
Post by andrew » Sun Feb 21, 2010 7:48 am
You can always reset QCAD by deleting its configuration file. See FAQ:
http://www.ribbonsoft.com/qcad_doc_faq.html#5
Post by andrew » Sun Feb 21, 2010 8:02 am
Note that if you are under Mac OS X, the preferences menu might be in the QCAD menu or the second last menu entry in the Edit menu.
BrianH
Post by BrianH » Sun Feb 21, 2010 12:33 pm
Preferences Greyed out.
Problem now sorted. Many thanks Andrew for you super fast reply. Brian
Locked
