Library entities duplicated
Locked
edgewing
Post by edgewing » Thu Jul 05, 2007 8:04 am
Just checking I'm not the only one before I log a bug report, has anybody had a problem whereby an entity is saved as a library component and when the library browsr is opened, it appears twice? This seems to be happening now with all my libraries.
These are in the electronic parts library. Also, there appears to be another set of parts under the transistors directory. Anybody aware of why they are there instead of in the correct spots?
rdohmeier
Post by rdohmeier » Tue Jul 15, 2008 10:29 pm
My libraries are all custom and the images in the library browser are duplicated. In addition, when I created new hatch patterns, all the hatch images in the hatch browser are duplicated. Any suggestions are welcome.
lathanial
Post by lathanial » Mon Aug 25, 2008 10:32 pm
I just purchased QCad and started creating blocks for the library. All of the entries are duplicated. Has anyone found the problem yet?
lathanial
Post by andrew » Tue Aug 26, 2008 10:36 am
Please do always indicate the exact platform (operating system, distribution, version) you are using when reporting problems. This is extremely helpful both for us and for other users who are trying to help.
lathanial
Post by lathanial » Tue Aug 26, 2008 1:37 pm
Sorry about that. Here's the information.
Operating System: Ubuntu 8.04
QCad Version: 2.2.1.0
Thanks,
lathanial
lathanial
Post by lathanial » Tue Aug 26, 2008 4:36 pm
This seems to correct the duplicate problem for this setup:
Apparently, QCad creates a folder .qcad/library that reflects the contents of folder ~.QCad/library. (note: I renamed my installation directory to QCad). Everything seems to work as expected if I just use .qcad/library as my library and delete ~.QCad/library.
lathanial
Locked
