Printing problem
Locked
mrklean59
Printing problem
Post by mrklean59 » Mon Jan 12, 2009 9:09 pm
When I print using the free version, printing is very light. When I print using the demo version, I save to pdf and printing is fine. Any suggestions would be appreciate,
Thanks !
apjjr
Post by apjjr » Sun Jan 18, 2009 10:13 pm
Set your line weights to something appropriate for the scale at which you are printing. I use .35mm for 1=1 scale printing of small parts. The line weight is scaled with the scale of the print out.
-Alex
mrklean59
Post by mrklean59 » Mon Jan 19, 2009 12:33 am
Thanks, I'll give that a try ; )
mrklean59
Post by mrklean59 » Mon Jan 19, 2009 6:10 am
I think that worked, but now my printer is not shown LOL! It works in other programs, but in Qcad I have to print to a file since no printer is shown,,,, any help appreciated !
Thanks again ~!
Post by andrew » Mon Jan 19, 2009 9:16 am
mrklean59 wrote:I think that worked, but now my printer is not shown LOL! It works in other programs, but in Qcad I have to print to a file since no printer is shown,,,, any help appreciated !
Thanks again ~!
Please indicate your operating system. If you are on Debian / Ubuntu, please refer to this thread:
http://www.ribbonsoft.com/rsforum/viewtopic.php?t=356
tonyv
Post by tonyv » Thu Apr 09, 2009 6:21 pm
Running QCAD 2.2.1.0 under Debian Testing. Using a HP photosmart C6200. QCAD finds the printer OK, but the Properties button is greyed out. When I attempt to print from QCAD, it tries to print to the photo paper. Other applications work fine if I set the paper source appropriately.
I do have the symlink to printcaps set.
Any suggestions, please?
Locked
