Imperial (US) drawing sheet templates, ANSI A-E
About the creation of DXF / DWG part library items.
Post by Husky » Sun Jul 28, 2013 9:06 pm
Hi guys - if you are in need of a couple "Imperial drawing sheet templates" - here we are :wink:
Well organized imperial Drawing sheets incl. Pr-defined Layers and Blocks for:
- Paper Frame,
- Title Block incl. Projection symbol 3rd angle (US),
- Zoned Border (Sub-Block of Paper Frame),
- Logo / Name (Sub-Block of Title Block - changeable!),
Drawing unit: inch
Linear Dimensions:
Dimension height: 1/8" (0.125 inch),
Format: Fractional, Precision: 1/32"
Scale 1"=1"
Easy to configure - visible/invisible how ever you like it,
Easy to copy/scale - everything on one Layer (Drawing sheet),
The "Drawing sheet" Layer is default locked - if you have to put Data into the Title Block you have to unlock the Layer ...
Imperial drawing sheet templates:
ANSI A / 28" x 11" Portrait,
ANSI A / 28" x 11" Landscape,
ANSI A.zip
(26.44 KiB) Downloaded 1656 times
ANSI B / 11" x 17" Landscape,
ANSI C / 17" x 22" Landscape,
ANSI B+C.zip
(26.38 KiB) Downloaded 2030 times
ANSI D / 22" x 34" Landscape,
ANSI E / 34" x 44" Landscape,
ANSI D+E.zip
(29.84 KiB) Downloaded 1365 times
Projection symbols,
Projection symbols.dxf
(85.05 KiB) Downloaded 1119 times
or ... at one go .zip ;-)
ANSI A-E.zip
(90.51 KiB) Downloaded 1363 times
All downloads are free for QCAD user!
Customize it how ever you like it!
Have fun!!! 8)
Update: Imperial (US) drawing sheet templates, ANSI A-E
Post by Husky » Wed Sep 25, 2013 8:33 pm
Hey - how nice is that!
With the new QCAD 3.3.0 release we have more and nicer possibility's to handle i.e. the entries in a title blocks or a revision block.
It's called "Block attributes" and that was a reason for me to update the Drawing sheet templates with this new feature of QCAD.
QCAD 3 - Video Tutorial (Q&E).
"Drawing sheet template with block attributes"
Long story short:
You will find in the .zip the same Drawing sheet templates as above but now with the new block attribute function.
ANSI A-E with block attributes.zip
(101.52 KiB) Downloaded 1233 times
Have fun! :wink:
BrushType4
Re: Imperial (US) drawing sheet templates, ANSI A-E
Post by BrushType4 » Mon Aug 03, 2015 9:36 pm
Hi, these are great. I would like to amend these to metric and United Kingdom standard paper sizes but I'm struggling to amend the templates successfully.
Post by Clive » Tue Aug 04, 2015 9:07 am
Hi , have a look here:
viewtopic.php?f=51&t=2047
They are also included with QCAD itself!
BrushType4
Post by BrushType4 » Tue Aug 04, 2015 1:53 pm
Thanks!
lwebb
Post by lwebb » Wed Nov 30, 2016 6:13 pm
I am unable to hear the tutorial. I have logged into YouTube and still can not get the audio to play. Is this located somewhere that I could download the file? :?:
Post by Husky » Wed Nov 30, 2016 6:35 pm
lwebb wrote:... Is this located somewhere that I could download the file? :?:
Unfortunately this Video is without Audio. :oops:
Flynny
Post by Flynny » Tue Feb 27, 2018 2:38 pm
Thank you very much for taking the time to produce this template!
Kind regards
luggw1
Post by luggw1 » Fri Nov 23, 2018 11:28 pm
Is it possible to enter a multi line title in the drawing title field?
Bill Lugg
Post by Husky » Sat Nov 24, 2018 5:26 am
Yes it is.
You are quit welcome to modify it to what ever suits your needs best. :wink:
luggw1
Post by luggw1 » Sun Nov 25, 2018 6:28 am
So, then you're saying by inserting text manually in the block, not through use of the field, right? Also, I take it Standard if the font you've used for the rest of the text in the title block?
The reason I ask is that some applications have a special key sequence to insert a carriage return into a text string (spreadsheets for example) and I wanted to make sure I wasn't missing something here.
Thanks for the response.
Bill Lugg
Return to “Creating DXF/DWG items”
