tooltips invisible
Post to this forum to introduce yourself to this forum if you are new here. You might want to include some information about the work you are doing or planning to do with QCAD.
swivel
tooltips invisible
Post by swivel » Thu Apr 30, 2020 2:54 pm
I am a new user of QCAD/CAM pro on iMac.
Installation seems ok but tooltips are invisible
Please assist
macOS Mojave
version 10.14.6
QCAD/CAM Version: 3.24.3.0 (3.24.3)
Internet: QCAD.org
Build Date: Mar 16 2020
Revision: 6e718a8
Qt Version: 5.13.2
Architecture: x86_64
Compiler: Clang 10.0.0
Re: tooltips invisible
Post by andrew » Thu Apr 30, 2020 3:39 pm
Does that mean that you cannot see any tooltips, i.e. nothing happens if your mouse hovers over a button or is there a problem with colors or the font of tool tips?
Are you using dark or light mode?
swivel
Post by swivel » Thu Apr 30, 2020 3:51 pm
using dark mode
Post by andrew » Thu Apr 30, 2020 3:55 pm
Could be a focus problem. Can you switch to another application and back to QCAD and see if that works?
swivel
Post by swivel » Thu Apr 30, 2020 5:40 pm
tried switching to another app and back
tried quitting QCAD and launching same again
tried iMac restart
all above without success ...
Post by Husky » Thu Apr 30, 2020 6:52 pm
tried iMac restart
Is QCAD the active running application? To be sure click with the mouse pointer anywhere in an free canvas area and hover then with the mouse pointer over a tool icon.
Post by andrew » Thu Apr 30, 2020 7:25 pm
Unfortunately, I cannot reproduce this problem here (also Mojave 10.14.6, QCAD/CAM 3.24.3.0).
Occasionally, this does happen, but I can easily fix it by switching to another app (Command-Tab, Command-Tab again). This is likely a but of Qt in combination with macOS.
I'd recommend to try one of the other packages for older macOS versions for example the one for macOS 10.10-10.13. This uses a different version of Qt.
swivel
Post by swivel » Fri May 01, 2020 5:49 pm
Tooltips suddenly reappeared.
Not sure about what triggered this, seems it was the resizing of the QCAD window ...
Let's seen how this behaves during the coming days.
Garball
Post by Garball » Fri Jul 30, 2021 2:57 am
Hi. I have the same problem now with my new mac mini running the new M1 processor, Big Sur 11.4 and
Qcad 3.26.4. I tried it on an older mac and don't have this problem. I can't learn this way so I'm wondering if there's a solution?
Thanks Gary,
Version:
3.26.4.0 (3.26.4)
Internet:
QCAD.org
Build Date:
Jun 3 2021
Revision:
0bb4334
Qt Version:
5.15.2
Architecture:
arm64
Compiler:
Clang 12.0.5
Post by andrew » Fri Jul 30, 2021 8:08 am
Please reset your QCAD configuration:
Return to “Introduce Yourself”
