Hi from Utrecht, Holland
Buntehuhn
Post by Buntehuhn » Wed Aug 06, 2025 7:09 pm
Hi all, I'm on the challenging route to become proficient enough in a 2D-CAD for my main hobby, RC gliders.
My first goal is to clean up a dxf-file from a 3D-CAD for RC-planes (DevWing) so I can cut it on the fablab laser cutter.
The fablab uses CorelDraw to output dxf-files to the laser cutter. Which is way out of my budget, so I've turned to open source tools (Inkscape, LibreCAD). Even with help form the LibreCAD forum I couldn't make the program behave as expected. So I purchased to QCAD and its manual.
Once I'm up and running I'll be happy to suport others on this forum.
Kind regards,
Arjan
