greetings from France
upworks
Post by upworks » Thu Nov 13, 2014 11:51 am
Hello qcad forum users,
I am leading my small electronics engineering company in Toulouse, France, and use qcad professional for every technical drawing need for custom enclosures machining, wiring diagrams and so on.
I use a commercial 3D software for enclosure design, but its 2D module is really bad compared to qcad, so I export dxf from this tool and work with qcad.
Qcad is really powerfull yet simple, stable, runs on linux, and cheap. I would definitively recommend it to every one !
Thank you for this great piece of software, continuous evolution and for this forum !
Laurent
Moderator / Drawing Help
Re: greetings from France
Post by Clive » Mon Nov 17, 2014 2:26 pm
upworks wrote:Qcad is really powerfull yet simple, stable, runs on linux, and cheap. I would definitively recommend it to every one !
Cheers Laurent
Welcome to the forum Laurent, great comments about QCAD and the forum :)
