Hello From India
Post to this forum to introduce yourself to this forum if you are new here. You might want to include some information about the work you are doing or planning to do with QCAD.
kamuthi
Hello From India
Post by kamuthi » Fri Oct 07, 2016 4:27 pm
Hi
This is Mohammed from India. Hope everyone fine.
I wants to make simple 2D layout for Plant and Machineries.
QCad is best option..?
Can i Open all Auto CAD files and edit via this QCad..?
Free trial option is enough for my task or needs to go for Pro..?
Thanks in Advance
Re: Hello From India
Post by Husky » Fri Oct 07, 2016 5:56 pm
Hello Mohammed - welcome to the QCad Forum!
kamuthi wrote:QCad is best option..?
Basically yes but it depends of what you are trying to achieve. :wink:
kamuthi wrote:Can i Open all Auto CAD files and edit via this QCad..?
Usually yes - we have many Autocad user which are working with QCAD.
kamuthi wrote:Free trial option is enough for my task or needs to go for Pro..?
This question can only be answered by yourself. The free trial/Community edition is already very powerful and for many user absolutely enough but - of course - it has not the same spectrum like the Pro edition. Test it by yourself with the Trial edition: http://www.qcad.org/en/qcad-downloads-trial and you can compare the differences between Community and Pro.
If you have any question please feel free to ask us. We are here to help! :wink:
kamuthi
Post by kamuthi » Fri Oct 07, 2016 6:13 pm
PRO will support open & Edit all dwg files upto AutoCAD 2016..?
Post by Husky » Fri Oct 07, 2016 6:33 pm
kamuthi wrote:PRO will support open & Edit all dwg files upto AutoCAD 2016..?
Pro will open/edit and save dwg's. The best thing to be absolutely sure is to make a test by yourself with the trial edition. Or if you have already an AutoCAD 2016 file you can attach it to this post or, if confidential, you can also use my PM and I will send you an screenshot of that opened file. But remember - we are talking about 2D and not 3D drawings.
Return to “Introduce Yourself”
