Hello everybody
mentanto
Hello everybody
Post by mentanto » Fri Nov 10, 2017 2:54 pm
Hola!
I use Qcad from 6 moths ago. I work in the electrical engineering department of a University of Valladolid (Spain) and we want to replace expensive software packages by open source solutions. I use Qcad basically to make designs and electrical lines drawings.
Re: Hello everybody
Post by Husky » Fri Nov 10, 2017 6:52 pm
Hello mentanto - welcome to the QCAD forum.
Jmvarsani
Re: Web development Help Australia
Post by Jmvarsani » Sat Nov 25, 2017 7:20 am
Hi Everyone,
I have read lot about QCAD and great things that can be done.
I am in glazing business and I want to develop web based software where the glazier can choose from list of templates and input measurement on the sketch or drawings and send the order to the glass processing company for his order.
By doing so the glazier will save lot of time and orders can be submitted to the supplier of the glass on real time.
Glass processor uses CNC machines to cut glass and do cut out on glass too. I am sure from what I have read this is possible using QCAD to output DXF files.
Please email me at jag@toughglass.com.au if anyone has worked on similar project
Once again thanks to everyone
Best Regards
Jag
Jag@toughglass.com.au
Post by Husky » Sat Nov 25, 2017 8:43 am
Hi Jag - welcome to the QCAD Forum.
Thanks for telling us about your plans - sounds interesting.
I'm sure browsing the Forum will answer most of your QCAD related question but if not please feel free to post them here and we'll try to help you.
Best Regards
