another new old guy
Post to this forum to introduce yourself to this forum if you are new here. You might want to include some information about the work you are doing or planning to do with QCAD.
petevick
another new old guy
Post by petevick » Mon May 25, 2020 8:28 am
Prior to retiring I was using 3D modelling software for steel structures called Tekla Structures, prior to that I used AutoCAD combined with Lisp routines that I had written myself to prepare structural steel fabrication drawings.
Since retiring I use cad for any projects around the house that need a bit of planning, I used Draftsight until they pulled the free version, then I eventually came across Qcad, which in many ways is a lot like using AutoCAD. I'd like to get into the scripting side eventually, just to keep me amused on the those rainy cold days.
Pete Vickerstaff
Linux Mint 19.3 Cinnamon, Qcad Pro 3.24.3
Re: another new old guy
Post by andrew » Fri Jun 05, 2020 10:44 pm
Thanks for your introduction and welcome to the forum!
Return to “Introduce Yourself”
