[solved] Well here I am
Maxwell-J
Post by Maxwell-J » Fri Dec 31, 2021 3:18 am
coming to you from Brisvegas (Brisbane Australia)
well versed in Generic Cadd, Autocad (yuk) and VCadd, now into QCAD after having dumped Windoze for Linux
used Cadd in general for doing maps, water depth charts and the occasional tech drawing for m/cycle parts, now retired and using it for bee hive drawings
have had a look around seeking what controls the open file(s) tab width, can someone point me in the right direction?
TIA Max
Re: Well here I am
Post by Husky » Fri Dec 31, 2021 6:13 am
Hallo Max - welcome to the QCAD forum.
... have had a look around seeking what controls the open file(s) tab width, can someone point me in the right direction?
QCAD doesn't have a control for tab width. You're able to make tabs visible or invisible below Application Preferences / Widgets and control open files below Menu / Window or shortcuts but there is currently no option to manipulate the width of a tab.
