Hello from KW, Ontario, CANADA
LenVW
Post by LenVW » Fri Apr 07, 2023 9:04 pm
I have been looking for a good software app for 2D CAD.
My history has been in process machinery for . . .
Food - Kellogg’s
Plastics - Big O Pipe
Fabrication - Central Ontario Metal
Pumps - JET and SIHI Vacuum Systems
LenVW
LenVW - KW Area
Re: Hello from KW, Ontario, CANADA
Post by Husky » Fri Apr 07, 2023 10:08 pm
Hi LenVW. Thanks for introducing yourself to the QCAD community. Welcome to the forum!
LenVW
Post by LenVW » Fri Apr 07, 2023 11:22 pm
Husky - What is the general feeling about QCAD compared to ACAD-2D ?
Do you have a ‘form’ letter about other member comments ?
I do not expect to do FEA or predictive failures . . .
But is the CNC g-code operational ?
LenVW
LenVW - KW Area
Post by Husky » Sat Apr 08, 2023 12:36 am
LenVW
Sorry - can't tell. I've not enough experience with ACAD-2D to be able to compare those products. The good news is that here in the forum are many ex ACAD"ler. Pretty sure they will share the experience with you. :wink:
