[solved] Interpolate arcs with line segments
I try to use the "Interpolate arcs with line segments" in the CAM configuration, but the generated tool path around a simple circle is only half a circle. I have tried this with different postprocessors without any luck. Did I miss a setting to get a full circular toolpath?
Thanks in advance
Thanks in advance
Re: Interpolate arcs with line segments
I cannot reproduce this problem. Please attach your DXF file and the output file (e.g. .nc) and indicate which post processor you are using.
Hello Andrew,
please find attached the following files:
circle.dxf - source file
Grbl_EASEL_MM.js - my modified postprocessor file (no line numbers)
LinInterpolationIsOff.nc - how the tool path should look like
LinInterpolationIsOn.nc - how the tool path looks if "interpolate arcs with lines" is switched on
CAM Config.jpg - screenshot of CAM Configuration.
Thanks for looking into this.
- CAM Config.JPG (141.3 KiB) Viewed 9307 times
- LinInterpolationIsOn.nc
- (6.88 KiB) Downloaded 360 times
- LinInterpolationIsOff.nc
- (152 Bytes) Downloaded 362 times
- Grbl_EASEL_MM.js
- (1.17 KiB) Downloaded 379 times
- Circle.dxf
- (117.03 KiB) Downloaded 364 times
Thanks. I can confirm this is a bug.
As a workaround, you can add this to your post processor:
This fix will also be included in the next QCAD/CAM release.
Grbl_EASEL_MM.prototype.getArcInterpolation = function() {
return Grbl.prototype.getArcInterpolation.call(this) && ((this.checkContext("CamOffset") && this.outputOffsetPath) || (!this.checkContext("CamOffset") && !this.outputOffsetPath));
Thank you Andrew.
Ich werde den work around heute ausprobieren.
Freut mich, dass ich helfen konnte.
Hello Andrew,
the work around does not seam to work. The tool path looks the same as before.
Please attach your modified post processor file, thanks.
Sorry I missed that.
- Grbl_EASEL_MM.js
- (1.41 KiB) Downloaded 375 times
Please move the new function (Grbl_EASEL_MM.prototype.getArcInterpolation = function ...) to the end of the file, otherwise the line
assigns a new prototype and deletes your function getArcInterpolation in the process.
Grbl_EASEL_MM.prototype = new Grbl();
- Grbl_EASEL_MM.js
- (1.41 KiB) Downloaded 443 times
Thank you very much Andrew. This time it worked perfectly.
