QCAD/CAM Gerber Import Problem
Christian
Post by Christian » Wed Feb 12, 2025 8:37 am
Hello together,
I bought version 3.32.0 two weeks ago. However, the “Gerber Import ...” option does not work for me. I can select the option in the menu and also select the files I want to import. However, the data is not imported afterwards. Nothing is imported.
I previously tested the trial version of version 3.25.2 for testing purposes and the import worked without any problems with this version.
My question to you now is what I am doing wrong. Have I set a setting incorrectly or has the import process changed?
Many thanks in advance for your answer
Christian
operating system: Windows 11 64bit
QCAD version: 3.32.0 Pro (problem) & 3.25.2 Trial (no problem)
Re: QCAD/CAM Gerber Import Problem
Post by andrew » Wed Feb 12, 2025 8:50 am
Thank you for your report. Please attach or e-mail the Gerber file in question, so we can help efficiently, thanks.
Post by CVH » Mon Feb 17, 2025 10:47 am
Informational: Bug report FS#2643 and fixed
Return to “QCAD/CAM”
