YouTube Howto's
srl
YouTube Howto's
Post by srl » Tue Jun 07, 2016 2:53 am
The posts here are not usually positive as not everyone has java script programming and fitter-turning trade experience. With mm / inches and different machine drivers and uses a one config for all is impossible. :cry:
With that out of the way I would like to show you what works for me and what I've learnt the last three or so years .
https://youtu.be/zneEmuUgSMc
srl
srl
Re: YouTube Howto's
Post by srl » Wed Jun 08, 2016 2:51 am
Setting the direction of a closed shape is important in order to get a climb or normal cut.
Here is a quick fix to set the direction of full circles.
Split full circles must be set for it to work.
https://youtu.be/cZtFOTMKBJ4
The changed function is as follows-
GCode.prototype.exportSingleContourEntity = function(entity, rampOnPoint, rampOffPoint) {
    this.orientation = this.getPathOrientation();  // enter this line to set the direction of split full circles.
    this.exportLeadIn(entity);
    if (this.hasLeadIn(entity)) {
        rampOnPoint = undefined;
    if (this.hasLeadOut(entity)) {
        rampOffPoint = undefined;
    this.exportContourEntity(entity, rampOnPoint, rampOffPoint);
    this.exportLeadOut(entity);
srl
srl
Re: YouTube Howto's
Post by srl » Thu Jun 09, 2016 12:31 am
The following function sets the direction of full circles that are not split in two. Just add it to GCode.js or your config.
It doesn't set the direction of full circles that have been split. The above post deals with that.
GCode.prototype.exportArcSegment = function(arc, allowForZeroLength) {
    var entity = this.getEntity();
    if(isCircleEntity(entity) && this.getPathOrientation() == Contour.Orientation.CW){
	arc.reverse();
    CamExporter.prototype.exportArcSegment.call(this, arc, allowForZeroLength);
srl
Re: YouTube Howto's
Post by andrew » Thu Jun 09, 2016 7:24 am
Thanks. I've applied both changes to GCode.js for future releases.
Return to “QCAD/CAM”
