Option for 'Roughing Out' first
Moderator
Post by Clive » Sat Dec 31, 2016 2:03 pm
Hi Andrew
Would there ba any options added in the new QCAD/CAM to rough out first?
Re: Option for 'Roughing Out' first
Post by andrew » Sun Jan 01, 2017 1:16 pm
Hi Clive,
What is planned is an "allowance" when creating a toolpath. For roughing, you can then create a roughing toolpath using a roughing tool with an allowance for the tool radius and optionally tool length. You would then in addition create the final toolpath using the same or another tool with zero allowance. I hope that makes sense.
Moderator
Post by Clive » Sun Jan 01, 2017 2:27 pm
andrew wrote:Hi Clive,
Yes Andrew it all makes sense, thank you, I understand everything ...so far :)
In fact I've got coming in the post a very good book that takes someone new to CNC routing from the beginning through all the basics.
Return to “QCAD/CAM”
