Buying CAM
jvalencia
Buying CAM
Post by jvalencia » Sun Mar 12, 2017 1:51 pm
I already own qcad pro but wanted to know if I can buy CAM module alone for it or do I have to buy another qcad pro with it.
I own a cnc that uses mach3 compatible code. I want to test it.
Re: Buying CAM
Post by andrew » Mon Mar 13, 2017 8:42 am
I've sent you an update code by e-mail you can use to get a discount when upgrading to QCAD/CAM.
jvalencia
Re: Buying CAM
Post by jvalencia » Mon Mar 13, 2017 6:01 pm
Thanks Andrew, I'll use it when the CAM big update is released :)
Return to “QCAD/CAM”
