Minor bug (cam 3.17)
jvalencia
Post by jvalencia » Sun May 21, 2017 2:27 pm
Toolpath dialog won't remember Lead In Type when Side/Direction set to "On".
It works as expected when Side is Outside or Inside.
Re: Minor bug (cam 3.17)
Post by andrew » Mon May 22, 2017 8:09 am
Thanks for your report.
Lead in / out are actually not supported if the toolpath is generated on the profile. For this reason, lead in / out are reset to None when side is changed to On.
I can probably provide more information if you can ellaborate on what you are trying to achieve with this setting.
jvalencia
Post by jvalencia » Mon May 22, 2017 5:25 pm
I was just trying things. If it's not supported, is it a bug that qcad added the path??
Return to “QCAD/CAM”
