Toolpath bug
jvalencia
Toolpath bug
Post by jvalencia » Sun May 21, 2017 6:44 pm
I selected some polylines (from exploded text) and created the tooltpaths.
Some of them are incomplete. I've attached the dxf.
cancela.dxf
(128.58 KiB) Downloaded 77 times
Re: Toolpath bug
Post by andrew » Mon May 22, 2017 8:06 am
Please try increasing the Tolerance for joining segments under
Edit > Application Preferences > Modify > Offset
For example to 0.01.
jvalencia
Re: Toolpath bug
Post by jvalencia » Mon May 22, 2017 5:32 pm
At 0.1 tolerance I still see incomplete paths. But the result has improved on other letters.
Re: Toolpath bug
Post by andrew » Mon May 22, 2017 5:38 pm
Note that the path for the A letter looks correct to me (assuming you didn't choose any lead in / lead out).
jvalencia
Re: Toolpath bug
Post by jvalencia » Tue May 23, 2017 7:55 pm
mm you're right on the "A", I'm used to see start and end on the same point (the toolpath).
Return to “QCAD/CAM”
