Compensation off must not be followed by arc - error
JSRoy
Post by JSRoy » Fri Sep 22, 2017 9:49 pm
Hi all,
I wanted my machine to cut the number 8 in wood. So I created the number 8 using QCAD/CAM, exploded the 8, configured and exported my cutting path using QCAD/CAM.
When I opened my .nc file using CNCLinux, it gave me a strange error:
The move just after exiting cutter compensation mode must be straight, not an arc
on line 23 of my .nc file.
Line 23, as generated by QCAD/CAM, is like so:
N230 G40 X1.625 Y2.1806
The error goes away if I change it like this:
N230 G40 G1 X1.625 Y2.1806
I'm very new at CNC and G-Coding. Any insight as to why I get this error?
Thank you,
JSRoy
test228.dxf
(614.28 KiB) Downloaded 461 times
test228.nc
(19.04 KiB) Downloaded 482 times
Re: Compensation off must not be followed by arc - error
Post by andrew » Fri Sep 22, 2017 10:38 pm
Please proceed as follows:
- Quit QCAD/CAM
- Save the attached files LinuxCNC.js and LinuxCNCIN.js into the postprocessors folder of your QCAD/CAM installation.
- Start QCAD/CAM and load the updated attached file test228.dxf
This will add the extra G1 for every G40.
Note that I've also changed your lead in / out to quarter arcs since the straight leads would have left you with a small bump where the paths start / end. Feel free to change those back if you had other reasons for that.
test228.dxf
(661.82 KiB) Downloaded 500 times
LinuxCNC.js
(289 Bytes) Downloaded 489 times
LinuxCNCIN.js
(294 Bytes) Downloaded 474 times
JSRoy
Post by JSRoy » Sat Sep 23, 2017 6:15 pm
Thank you for the fix, it works fine!
Return to “QCAD/CAM”
