Compensation off must not be followed by arc - error
Posted: Fri Sep 22, 2017 9:49 pm
Hi all,
I wanted my machine to cut the number 8 in wood. So I created the number 8 using QCAD/CAM, exploded the 8, configured and exported my cutting path using QCAD/CAM.
When I opened my .nc file using CNCLinux, it gave me a strange error:
Line 23, as generated by QCAD/CAM, is like so:
The error goes away if I change it like this:
I'm very new at CNC and G-Coding. Any insight as to why I get this error?
Thank you,
JSRoy
on line 23 of my .nc file.The move just after exiting cutter compensation mode must be straight, not an arc
N230 G40 X1.625 Y2.1806
N230 G40 G1 X1.625 Y2.1806
Thank you,
JSRoy
