Tool Depth Change
Dreamaker
Tool Depth Change
Post by Dreamaker » Thu Oct 12, 2017 9:00 pm
I Cut my VacBracket and noticed something strange. When I setup the tool depth for the 6.22 mm end mill, in the Cam tool setup, I set it for Z-12.3 from the top of the material. When I converted to G-code all the depths, were changed to Z-11.6167 mm by the converter. Why did it come up short in the conversion.
VacBracket2.dxf
(847.26 KiB) Downloaded 68 times
VacBracket2.nc
(26.75 KiB) Downloaded 68 times
Re: Tool Depth Change
Post by andrew » Fri Oct 13, 2017 2:45 pm
I can confirm that there is a problem (rounding issue) which prevents QCAD/CAM from diving to the final level in this case.
A snapshot release (QCAD/CAM 3.18.1.2) is available which fixes the issue. I will send you a download link via private message.
Dreamaker
Post by Dreamaker » Sat Oct 14, 2017 3:45 pm
That worked! Thank You!
Return to “QCAD/CAM”
