[Solved] Contour generation fails
RobB
Post by RobB » Sat Jun 13, 2020 7:59 pm
Outer contour generation seems impossible for this simple object (attached). Redrew it at least 10 times to make sure the lines all connect, turned around to see if it would work better, gave up after about an hour of trying. What is wrong here? Still incorrect connected lines?
Thanks for help,
Robert
test27.dwg
(29.93 KiB) Downloaded 125 times
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: Contour generation fails
Post by Husky » Sat Jun 13, 2020 8:12 pm
Nope - duplicates ... :wink:
You may doublecheck the big (R33) radii ...
RobB
Re: [Solved] Contour generation fails
Post by RobB » Sun Jun 14, 2020 8:48 am
Thanks...
Robert
Return to “QCAD/CAM”
