[solved] QCAD 3.25.0 Professional doesn't work in Linux
Valeria367
Post by Valeria367 » Fri Aug 21, 2020 7:30 pm
Hi, Everyone. Good evening.
I'm one user of QCAD Professional from some years ago in both OS: Windows and Linux (ElementaryOS). Today I've download the last version (3.25.0) and install it. The Windows version runs correctly, but the linux version doesn't. When I try to run it, I get the next errors log:
QCAD version 3.25.0
Warning: QApplication: invalid style override passed, ignoring it.
Warning: RPropertyTypeId::generateId: property already initialized: 7RObject : "" : "Invisible"
20:11:44: Debug: RGLES3DPlugin::initScriptExtensions
Warning: QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Warning: QOpenGLWidget: Failed to create context
20:11:46: Debug: checking for QCAD Pro updates...
Warning: QSslSocket: cannot resolve CRYPTO_num_locks
Warning: QSslSocket: cannot resolve CRYPTO_set_id_callback
Warning: QSslSocket: cannot resolve CRYPTO_set_locking_callback
Warning: QSslSocket: cannot resolve ERR_free_strings
Warning: QSslSocket: cannot resolve EVP_CIPHER_CTX_cleanup
Warning: QSslSocket: cannot resolve EVP_CIPHER_CTX_init
Warning: QSslSocket: cannot resolve sk_new_null
Warning: QSslSocket: cannot resolve sk_push
Warning: QSslSocket: cannot resolve sk_free
Warning: QSslSocket: cannot resolve sk_num
Warning: QSslSocket: cannot resolve sk_pop_free
Warning: QSslSocket: cannot resolve sk_value
Warning: QSslSocket: cannot resolve SSL_library_init
Warning: QSslSocket: cannot resolve SSL_load_error_strings
Warning: QSslSocket: cannot resolve SSL_get_ex_new_index
Warning: QSslSocket: cannot resolve SSLv2_client_method
Warning: QSslSocket: cannot resolve SSLv3_client_method
Warning: QSslSocket: cannot resolve SSLv23_client_method
Warning: QSslSocket: cannot resolve SSLv2_server_method
Warning: QSslSocket: cannot resolve SSLv3_server_method
Warning: QSslSocket: cannot resolve SSLv23_server_method
Warning: QSslSocket: cannot resolve X509_STORE_CTX_get_chain
Warning: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_noconf
Warning: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_conf
Warning: QSslSocket: cannot resolve SSLeay
Warning: QSslSocket: cannot resolve SSLeay_version
Warning: QSslSocket: cannot call unresolved function CRYPTO_num_locks
Warning: QSslSocket: cannot call unresolved function CRYPTO_set_id_callback
Warning: QSslSocket: cannot call unresolved function CRYPTO_set_locking_callback
Warning: QSslSocket: cannot call unresolved function SSL_library_init
Warning: QSslSocket: cannot call unresolved function SSLv23_client_method
Warning: QSslSocket: cannot call unresolved function sk_num
Warning: composeAndFlush: makeCurrent() failed
20:11:47: Debug: no updates available
20:11:47: Debug: RGLES3DPlugin::initScriptExtensions
20:12:12: Debug: done
Warning: QSslSocket: cannot call unresolved function ERR_free_strings
Thanks in advance. And greetings.
Re: QCAD 3.25.0 Professional doesn't work in Linux
Post by andrew » Fri Aug 21, 2020 7:48 pm
Is this QCAD Professional or QCAD/CAM? In the latter case, you might want to remove the OpenGL plugin:
plugins/libqcadgles3d.so
Valeria367
Post by Valeria367 » Fri Aug 21, 2020 8:30 pm
Hi, Andrew. Good evening.
It's QCAD/CAM.
How I can to remove the OpenGL plugin?
Thank you very much.
Post by andrew » Fri Aug 21, 2020 9:47 pm
You'd have to remove the file
from your QCAD/CAM installation.
Valeria367
Post by Valeria367 » Sat Aug 22, 2020 3:45 pm
Hi, Andrew. Good afternoon.
OK, I did it. Now works perfectly!!! :D :D :D
Thank you very much. And greetings.
Return to “QCAD/CAM”
