I recently downloaded & installed the QCAD/CAM and every time I try to open it I get a error code 0xc000007b. Does anyone know what could be the problem?
I've went through and clicked 'show hidden files'....'run as administrator' but no luck.
Error code 0xc000007b
- Capture2.PNG (7.27 KiB) Viewed 3529 times
Re: Error code 0xc000007b
Can you please try to remove the OpenGL plugin "qcadgles3d.dll" under the "plugins" folder in your QCAD/CAM installation?
A broken OpenGL setup seems to be the most likely culprit for problems with running QCAD/CAM.
