Milling out the entire area of a polyline
lagnat
Post by lagnat » Sat May 15, 2021 5:14 pm
As the subject implies I'd like to mill out the area described by a polyline but I've not seen any (easy) way to do it.
I've tried to create a series of concentric polylines, each one smaller by the diameter of the tool but selecting them an adding them to the tool path seems to confuse QCad. My guess is that it's not sure what the "inside" is and every other path goes on the wrong side of the line. I haven't tried creating a separate tool path for each one but my guess is that it would work.
Re: Milling out the entire area of a polyline
Post by andrew » Sat May 15, 2021 5:16 pm
Please refer also to:
viewtopic.php?f=74&t=5411
lagnat
Post by lagnat » Sat May 15, 2021 5:33 pm
That looks like it'll work. Thanks!
lagnat
Post by lagnat » Sat May 15, 2021 6:22 pm
Well.. it almost worked. It's generating some strange tool paths that go way outside of the polyline.
Screen Shot 2021-05-15 at 1.21.11 PM.png (106.26 KiB) Viewed 7475 times
xx.dxf
(154.21 KiB) Downloaded 365 times
Post by andrew » Sat May 15, 2021 9:09 pm
In the CAM Toolpaths list, double-click on "Profile 1".
Set the "Overcut" parameter from "2" to "0".
lagnat
Post by lagnat » Sat May 15, 2021 9:55 pm
That's interesting. Isn't that just for leads, which I have disabled?
Return to “QCAD/CAM”
