Nesting unable to fit all pieces
Nube
Post by Nube » Wed Jun 16, 2021 12:15 pm
I recently use the nesting function but it could not be able to fit all pieces.
I enclose the source drawing and the solution drawing I found without nesting function.
Am I doing something wrong?
https://qcad.org/rsforum/download/file. ... w&id=10130
Nesting solution.dxf
(29.61 KiB) Downloaded 438 times
Nesting source.dxf
(31.13 KiB) Downloaded 335 times
Re: Nesting unable to fit all pieces
Post by andrew » Wed Jun 16, 2021 12:19 pm
Please understand that the nesting algorithm is not a puzzle-solver. It simply tries to guess how pieces might fit best. It is absolutely possible that you might find a better solution by manually placing pieces. If you spend enough time doing so, that's even very likely.
Nesting is mainly useful in cases where finding a solution manually is not feasible (e.g. large number of small irregular pieces).
Post by CVH » Wed Jun 16, 2021 1:39 pm
From what I can see ... and have to deduct from that. :wink:
Sheet = 3000x1000 (the largest open contour)
16 pieces to nest.
All 16 are fitted on the sheet. :P
Nube
Post by Nube » Wed Jun 16, 2021 5:26 pm
ok, i have no experience on that, now is more clear
Nube
Post by Nube » Wed Jun 16, 2021 5:28 pm
16 pieces to nest.
You mean that you could fit them using the nesting function?
Post by CVH » Wed Jun 16, 2021 6:33 pm
From what I can see in your two files:
- Nesting source.dxf (before)
- Nesting solution.dxf (after)
QCAD nested all 16 shapes on the larger sheet.
Seems to me that all was OK to begin with.
Nube
Post by Nube » Thu Jun 17, 2021 12:57 pm
This means I made some mistake using the nesting function.
But I was lucky I could solve it manually otherwise I needed another slab 3000x1000 of Laminam porcelain gres.
The drawing was not complete, there were 3 rectangulare holes missing, necessary for other 4 pieces (the pieces were 20 really), because i was not sure how this could behaive with nesting function, anyway here is the final result:
Return to “QCAD/CAM”
