Hi
In Qcad/Cam are some command to do Enclosing rectangle this help me for know dimension of exist geometry and to position geometry on zero point.
Versions
QCAD version: 3.26.4.0
Date: Jun 4 2021
Qt version: 5.13.2
Compiler version: MSVC++ 14.0 (2015)
Build date: Jun 4 2021
Revision: 0bb4334f11f4340e470c4135ae61c076a98f919f
[solved] Enclosing rectangle
Re: Enclosing rectangle
I think that you mean Create Polyline from ... Segments (OG)/Selection (OC)
Menu .. Draw .. Polyline ..
QCAD will reqognise squares and rectangle shapes.
See 'Size' property in Property Editor.
For positioning one can also select connected entities ... Double click one of the segments.
Moving with reference point snapping to Middle Manual and two extreme positions.
Hi
I want create one rectangle around de geometry Selection (OC) automatic
- EX.dxf
- (114.39 KiB) Downloaded 315 times
Select the shape, launch the tool "Draw bounding box" below Menu / Misc / Draw
YES YES YES
THANKS
THANKS
